RCU Forums - View Single Post - Servo Failures
Thread: Servo Failures
Old 03-29-2015 | 07:17 PM
  #33
sidgates
Originally Posted by JPMacG
Sorry, I did not check back until now. Two of them I was running them on 6 volts (a 5 NiCd cell pack). They were rated for 6 volts. They were HS-225MGs. I don't recall what voltage I had on the third one that failed. It might have been 4.8 or 6 volts.
The only Hitec servos I have had fail were the HS-225's about 4 years ago. Two of my flying friends also had failures of the HS-225. All were motor brush failures, the brushes appeared wear excessively in fairly short operating time probably from over heating. If you had 5 cell pack you were probably over 6 volts coming off the charger.
We replaced the motors (appeared to be a new design) with new ones and no more failures.
