RE: TF 1/5 Scale P-51 ARF Assembly Thread
Canopy attachment
Splais, You might want to try gluing the canopy on after you get the paint fixed. Canopies attached with screws generally dont last. The screw hole is a great place for a crack to start. I glue all of my canopies on with RC56 canopy glue. It dries clear and sticks great to monokote. Best part is, if you ever have to remove the canopy, use an old apc prop and slip it in the glue joint, pry it off all the way around and you will be able to re-use the canopy again. The old glue will peel off the original canopy. I did this on my world models P-51 MA and it worked great.
Evan Q.
