RCU Forums - View Single Post - Tee Dee Frustration
Old 03-31-2015 | 06:17 AM
aspeed's Avatar
aspeed
Sometimes it works best if the pickup in the tank is about 1/4" from the back so it doesn't richen on acceleration. Might be worth a try. Could also be a large venturi. They are kind of fiddly without pressure, if that is the setup you are using. It could be from the tank being outboard or inboard too much, but I doubt that is the problem if it only goes two feet.
