RCU Forums - View Single Post - First ever Simmer 600 build on RCU!!!
Thread
03-31-2015 | 02:44 PM
3
FlyWheel
Dec 2008
164
Blackstock, SC
Built the WashBoard
This will not only let me construct the wings with washout built in, but will also let me accurately set the dihedral angle. I made it a bit bigger than necessary for this bird so it can accommodate larger wing sections in the future. Each side measures 10" x 48" and can be unfolded (completely flat if necessary) to accommodate two wing sections. It was fabricated from two 1" x 10" x 48" pieces of pine, a continuous hinge cut to 10", four 1/2" corner brackets, Two 1/4-20 x 8" carriage bolts, six 1/4-20 nuts and of course the pin-board and assorted wood screws. Construction is simple and straightforward enough that anyone should be able to copy the design from the photos.
02:46 PM
. Reason: Added title
Reply
Like
FlyWheel
View Public Profile
Send a private message to FlyWheel
Visit FlyWheel's homepage!
Find More Posts by FlyWheel
View iTrader Profile
