Hi,
Yes I will be attempting to dremel two additional prop slots in the original spinner. I'll make a template of the shape to be removed and take it slowly with the dremel, I'll drill a few holes first and work away with a grinder or maybe the metal cutting dick first then grind away...nothing to loose and if successful it will look great as the yellow on the prop matches the spinner quite well.
