well after much effort and great pains the air system is in and the only thing left is to mount the pressure gauges. I mounted the brake system to the side wall like I always do and after all this I pray for no leaks. Air systems on this level are a pain!!!
Now that the cockpit and air things are done I can finish up the build this weekend by jumping back to the rudder and wing rod/control horn install. Once this is done, the f-14 is done except for final setup just like the Avanti. I will have to move everything down to the garage and get the turbines ran up and prep for maidens. Im still working the site to test fly, I am hoping to use a small airport about 40 mins away but well see. I have a lot to do before MS Jets, the trailer needs some new tires and I have to make a small trip to get a new project.
Cheers!!!
