RCU Forums - View Single Post - Ir help
Thread: Ir help
Old 04-02-2015 | 06:38 PM
Shorty54
Default Ir help
Quick rundown on equipment. I have 3 Taigen Tanks, all IR, all with new TK22 Clark Boards. I have installed the IR LEDS that came with the boards, I believe they are IR010. I made a tube in the turret to fit the IR LED into. I drilled out the hole in the mantlet to 6mm and set the LED back 9-10mm from the front of the mantlet to the front of the bulb. The problem Im having is that the tanks will take hits from each other when they are in different rooms, back to back, side by side, or not even facing each other. I have the stock Taigen Battle Unit or Apple as some call it. Any ideas on what I did wrong??
