DeltaRay and Phoenix 5 problem
I've been trying to fly the HobbyZone DeltraRay in Phoenix 5 simulator, but I'm having an issue with the ailerons. If the ailerons (elevons) are neutral and I pull a slight UP, the ailerons go down. A slight bit of additional UP and they then go up.
Is there a way to fix this in the simulator? This does not happen when I use any other airplane model.
Jack
