I glassed the bottom of the nose. That is as far as the nose is going to go for a while. While I had the glass and west systems out, I stiffened the ends of the fuel tank for my Panther. I cut and marked the fuel tank floor. I may use use it as a crutch and start the fuse inverted. It will need to be supported off the table by 10" for everything to clear. The doubled up quart paint cans are not going to be used. It was the only thing I had to temporarily get a look. I need to come up with the wing plug ins / landing gear mounts before any of the bulkheads get stood up.
