RCU Forums - View Single Post - M4a1
Thread: M4a1
Old 04-05-2015 | 02:06 PM
  #59
RichJohnson's Avatar
RichJohnson
Yep, I am going to play with that next, here is why.
On the barc3, if you turn off track recoil you loose the gun fire command and the tank does fire the IR, (I think) but no gun fire sound. I don't know if Dan found a fix around that or not.
We will see in a few minutes.
Update-
Yep, still set up like the BARC3. If you turn off the track recoil you loose the gun fire sound. Servo still pulls back and the lights still work but no sound. Mabye I will disable recoil during battle just to make it easier.
I bet Dan can comment, I think this is were a Bendini comes in because it adds the gunfire sound and hit sounds if you set it up like that.
