RCU Forums - View Single Post - Ignition causing servos to twitch
Old 04-05-2015 | 05:38 PM
APGSpyder
Question Ignition causing servos to twitch
I'm setting up a Great Planes Giant Yak 54 with a Fuji 43. I have the ignition battery located all the way up on the firewall and a Sullivan gold-n-rod running from the throttle back to a standard futaba servo mounted in the default location in the built in tray. When idling I get some twitching out of the aileron servos. I moved the receiver and the receiver battery as far back as I can without messing with the CG but I still get a twitch... running the Futaba 10CAG. Thoughts or ideas as to what is causing or how I can get rid of the interference? I don't want to put this bird up unless I know for sure that everything is solid!
Thanks.
