RCU Forums - View Single Post - Ignition causing servos to twitch
Old 04-06-2015 | 02:42 AM
Rodney
What radio system? Is it 72MHz or 2.3GHz? Are there any metal to metal contacts anywhere in the plane: if so that could be causing problems when any vibration rattle the connections. Do you have the spark plug shield making good contact with the motor? As to using Golden Rod, I use it a lot with no problems at all, just make sure the guide can not flex or bow under vibration.
