RCU Forums - View Single Post - Ignition causing servos to twitch
Old 04-06-2015 | 06:04 PM
mackeyjones
Originally Posted by APGSpyder
Is there a better way to mount the engine other than directly to the firewall? Like use a soft mount??? Not sure on the loose connections... I went through and any extension I added I tied the connectors together and then put a piece of heat shrink over them to make sure they wouldn't come apart. I've padded the ignition module along with the receiver and batteries too. Prop has been balanced but I do notice a good amount of vibration. This is my first gasser so I've been trying to double check everything going together and setting it up with what I believe is the right way based on the manual and posts I have been reading around here too.
Yes there is a soft mount system for gas motors, just not sure you would be converting one issue to another, soft mounting motors come with other issues.
