Originally Posted by
wfield0455
Still, since you mentioned that you have 2 receivers, if you split the airplane left side / right side then simply have 2 gyros and stabilize the left side with one and the right side with the other. Then you have the same level of redundancy you have with 2 receivers and 2 batteries.
I was just thinking about it...and this product "Jeti Enlink2rs" comes to mind.....Here is how (I think) two receivers could work.. using the (Jeti Enlink2rs)...connect the red input lead to the output from the Gyro which is on (1 RX), Then connect the other black input lead to (2RX) corresponding channel. The output of the (Jeti Enlink2rs) goes to 1 out of two servo.. Ail, Elev, rudd, so if the gyro stop working the Enlink secondary input takes over.
But that's two much work
..back to old school flying
