Originally Posted by
basimpsn
I was just thinking about it...and this product "Jeti Enlink2rs" comes to mind.....Here is how (I think) two receivers could work.. using the (Jeti Enlink2rs)...connect the red input lead to the output from the Gyro which is on (1 RX), Then connect the other black input lead to (2RX) corresponding channel. The output of the (Jeti Enlink2rs) goes to 1 out of two servo.. Ail, Elev, rudd, so if the gyro stop working the Enlink secondary input takes over.
But that's two much work
..back to old school flying
Hey what's up Basil? When are you going to be back SFL? Are you using a Jeti system? Would there be any advantage in using a receiver with a gyro integrated into it? I know Spectrum has the AS3X receivers and Jeti is coming out with their entry into to the receiver / gyro combo unit. I'm trying to get back into the hobby and I'm interested in setting up with a gyro for the first time. Any info would be appreciated.
Andre.
