Originally Posted by
martinan
Hey what's up Basil? When are you going to be back SFL? Are you using a Jeti system? Would there be any advantage in using a receiver with a gyro integrated into it? I know Spectrum has the AS3X receivers and Jeti is coming out with their entry into to the receiver / gyro combo unit. I'm trying to get back into the hobby and I'm interested in setting up with a gyro for the first time. Any info would be appreciated.
Andre.
What's up Andre
..I tried to visit Markham Park as much as possible but D.C being the central point to my job... I'm stuck here
. The (Jeti Enlink2rs) is only a redundancy switch if you're using two receivers to one servo like a single rudder or throttle . If I wasn't using Futaba 2.4 system..Jeti radio gears seems rock solid enuff. Stay away from receiver/gyro combo unit, because if one goes bad you lose both. As for gyro I'm seriously looking into it...doesn't make sense everyone using gyros to improve the "PLANE STABILITY" and I'm hand flying mines like a su@#er lol.
