Ok lets get this all straight, first of all Dean fills out all the AMA forms with the correct info so that is what the AMA needs. Next the only danger to Dean is if the score keeper does not want to play along with the game and Dean uses different names at different races he will not get all his points at the end of the year. He gets hurt no one else does. Now the CD of the event can say no to Dean and use his correct name on the heat sheet. Now Dean is not the first one to do this and I've seen it several times in the past and I've been racing since the early 90's. Hope this helps and again it's up to the CD.
