Originally Posted by
JohnnyS
I read that it was not really successful: The single Martin K.III Kitten could only climb to 295 feet (Slightly higher than Lake Ontario above sea level). If you need oxygen at that altitude, you have some *serious* medical problems.
The next version, the Martin K.IV Kitten, came out a few years later and was more successful: It could apparently get up to 11,400 feet.
Another 1100' the pilot in command would be required to use supplemental OX2 avter 1/2 hour at that altitde. If I remember my FAR's concerning alttudes concerning supplemental OX2
That's if the FAA/CAA existed in 1919
OH Crap Just had to Google it anyway.
Sec. 91.211 — Supplemental oxygen.
(a) General. No person may operate a civil aircraft of U.S. registry—(1) At cabin pressure altitudes above 12,500 feet (MSL) up to and including 14,000 feet (MSL) unless the required minimum flight crew is provided with and uses supplemental oxygen for that part of the flight at those altitudes that is of more than 30 minutes duration;
(2) At cabin pressure altitudes above 14,000 feet (MSL) unless the required minimum flight crew is provided with and uses supplemental oxygen during the entire flight time at those altitudes; and
(3) At cabin pressure altitudes above 15,000 feet (MSL) unless each occupant of the aircraft is provided with supplemental oxygen.
(b) Pressurized cabin aircraft. (1) No person may operate a civil aircraft of U.S. registry with a pressurized cabin—
(i) At flight altitudes above flight level 250 unless at least a 10-minute supply of supplemental oxygen, in addition to any oxygen required to satisfy paragraph (a) of this section, is available for each occupant of the aircraft for use in the event that a descent is necessitated by loss of cabin pressurization; and
(ii) At flight altitudes above flight level 350 unless one pilot at the controls of the airplane is wearing and using an oxygen mask that is secured and sealed and that either supplies oxygen at all times or automatically supplies oxygen whenever the cabin pressure altitude of the airplane exceeds 14,000 feet (MSL), except that the one pilot need not wear and use an oxygen mask while at or below flight level 410 if there are two pilots at the controls and each pilot has a quick-donning type of oxygen mask that can be placed on the face with one hand from the ready position within 5 seconds, supplying oxygen and properly secured and sealed.
(2) Notwithstanding paragraph (b)(1)(ii) of this section, if for any reason at any time it is necessary for one pilot to leave the controls of the aircraft when operating at flight altitudes above flight level 350, the remaining pilot at the controls shall put on and use an oxygen mask until the other pilot has returned to that crewmember's station.
NEXT: Sec. 91.213 - Inoperative instruments and equipment.
PREVIOUS: Sec. 91.209 - Aircraft lights.
Search the FARS for
