RCU Forums - View Single Post - Tamiya recoil problem help needed
Old 04-10-2015 | 12:04 PM
TheBennyB
Once you have the recoil unit out also look at the bottom nut that holds the main gear in place. They have a notion of coming loose then the main gear will skip off the worm gear or drop gear depending on which unit the IS-2 uses. If it is off, look in the lower hull for it then screw it back on and use a tad of thread lock to keep in place.
