Originally Posted by
Maj_Overdrive
As far as I know Hobbi o is a distributor for OS and doesn't actually own them. I'd assume OS, like other engine manufacturers, does make engines "to spec" for other manufacturers. Now a "to spec" engine can be the same as an engine in their normal lineup but with a different cooling head, different porting, or different materials and machining processes to lower costs of the manufacturer contracting OS wants a lower spec. If a particular "to spec" engine is not offered in OS normal product lineup then Hobbico and other distributors wouldn't have any info on it. SH makes engines "to spec" for LRP, Losi, Redcat and others.
Both OS and SH make good engines, but what Redcat spec'd for each is unknown. Ultimately I think your decision is going to have to be based on how bad you want the electric starter. Removing and installing the flywheel isn't hard. You simply hold the flywheel (a tool like a pair of channel locks may be needed), remove the flywheel nut and tap the flywheel lightly around the backside to break it loose. Don't forget to remove and save the collet on the crankshaft behind the flywheel.
The issue is the backing plate that has the opening for the the wand end. It bolts onto there older engine. but they updated to OS engines and haven't replaced a new backing plate that fits the OS engine. One of the issues is Redcat has a" you might like" section and shows a electric start set. so most people would assume it would fit on that vehicle. Then when you call Redcat and get a person grumpy day or whatever then everything go,s bad from there.
Mr. Bob
Countyline Hobbies
Grovertown, IN.
574-540-1123
[email protected]
www.countylinehobbies.com
