Originally Posted by
stegl
did you have a C&H ignition originally or did you replace the old ignition with w new C&H ? Thanks God the problem fixed !
I replaced the original Fuji ignition that came with the engine. I though if it would work with foil on the spark wire I would get a braided sleeve. When I put the foil on it it wouldn't even start. Not even a pop out of it. Decided that was enough and got the C&H Ignition.
