First of all, if you are detecting a resistance from the carburetor barrel send the engine to where you got it and have them fix the problem. Second, you are not supporting the cable at enough points to avoid flexing. Third, the geometry you are dealing with is working against you especially at the engine. I’ll attach a couple of images of one of my installations to help you out. Dan.
