RCU Forums - View Single Post - Throttle cable flexing (binding) 15cc Evolution.
Old 04-12-2015 | 05:03 PM
rt3232
Jeff
Something I have done that has worked, for me in a tight install. With the engine removed and the cable free to be pulled out a bit carefully tin the cable back into the area just before the first bend, this will give you a stiff rod effect from your first bend to the carb. also make sure your end point on the servo is correct.
Just a thought
Cheers Bob T
AMA13377
