RCU Forums - View Single Post - RCPRO World Points 2015
Old 04-13-2015 | 09:23 AM
dakotapusher's Avatar
dakotapusher
While I have no objection to the use of pseudonyms, it is ultimately up to the CD for each event. From now forward I will post the scoring using the names provided to me by the event CD’s (with the exception of typos). I have changed the original scoring post to put Dean on the list in bronze as that is how it was provided to me.
However LB2311 does have a point in that using a pseudonym could cause some confusion as to the actual scoring tallies. To that end if you use more than one name during the season and the CD’s agree to the use of that name the score will be split between those names and no amalgamation at the end of the season will be given (if you use two names there will be two scores). That will make it fair for contestants that are in the points chase and may not know that someone is using a pseudonym. So if you want to use a pseudonym and the points matter to you it is in your best interest to clear it with all of the CD’s before using it and is best to do so prior to the start of the season.
In your case Dan it won’t matter much at this point since you’re in last place anyway.
