A little update - covering done, hinging done. I think it needs a little something on the vertical tail. Servo hook-ups, final assembly and balancing to do. I did a rough weight check, and it looks like it will be close to 3lbs even, so right where it should be. Went with the plastic wheel pants painted with Ultrapaint. It's no longer available, but I happened to have some yellow on hand, though the colour match isn't the greatest - another reason to make them from balsa..?
John
