RCU Forums - View Single Post - Help - spinning copter
Old 04-13-2015 | 08:43 PM
toglhot
Default Help - spinning copter
My copter has started spinning.
On the ground it spins wildly with the trim control central,. Moving the trim control either left or right just changes the direction of the spin. In the air it does the same only faster. It lifts of easy and because it is spinning stay in place.
It is branded LS-Model and is a .5 channel coaxial.
The remote just has four controls:
up/down joystick,
left/right/foward/back joystick,
slide trim control,
on/off switch, and
a switch at the top marked AB.
I think the last is for charging:
A - USB charging,
B - remote unit charging and
C - no idea at all. Directions were written in very bad Chinglish so had to work everything out myself.
I've had so many problems with this thing, it seems you get to fly it for 5 or 6 minutes then spend the rest of the hour fixing it. Is this as good as these things gets, if it is I'm done.
[TABLE="class: tborder user-postbit-left-user, width: 100%, align: center"]
[TR]
[/TR]
[TR]
[TD="class: alt2"]
[/TD]
[/TR]
[TR]
[TD="class: user-postbit-bottom-user"]
[/TD]
[/TR]
[/TABLE]
