RCU Forums - View Single Post - Any info for covering on which to use and what techniques
Old 10-14-2003 | 06:40 PM
Balsa Master's Avatar
Balsa Master
Default RE: Any info for covering on which to use and what techniques
i like monokote, and to get it tight tack al around the outside then hit with heat gun... for some reason, i still cover better withough heatgun... is this normal?? i can do a perfect covering )no wrinkles) with just an iron but if i use the heatgun its messes it all up...
