Originally Posted by
ron12901
I have a quick question on how to set up the throttle with my Taranis for a gas engine. I would like to know what is the best way to set the low end end point and also how to set an exponential curve from low to high. Thanks for any recommendations.
Ron,
I will outline my method, others can add their ideas.
I start with "Inputs" and "Mixers" set at 100% for throttle. I pick a hole on the servo arm or wheel that gives me as close to full travel on the carb as I can get. Next with the engine running I would fine tune the throttle "mixer" setting the give the idle I want and then fine tune the high end for full open carb.
I haven't used the "curves" function yet but I think you could adjust the throttle channel for the throttle response you desire. I hope some else can help you there.
