Originally Posted by
vertical grimmace
Invert, did you use a fixture to shape the litho around the stab/fuse transition? I am trying to work that spot out now. Any tips would be great.
Nope, just worked the metal. You've got to anneal it to get it soft enough to work, then you have to cut a panel about 1/2" larger all the way around so as to keep it small enough to work without wrinkles, but large enough to cover the area. It also has to be done in gwo pieces, just like the real one.
