Originally Posted by
invertmast
Nope, just worked the metal. You've got to anneal it to get it soft enough to work, then you have to cut a panel about 1/2" larger all the way around so as to keep it small enough to work without wrinkles, but large enough to cover the area. It also has to be done in gwo pieces, just like the real one.
Cool. Thanks for the info. I will give it a go tonight.
