OR I sell the BARC system that converts the RX18 over to a hobby grade radio with a completely Tamiya compatible battle system as well. You can add momentum and lose the HL hull recoil at the same time.
If you are happy with the Heng Long elevation cam it is plug and play and can be installed in less then 5 minutes.
There is a pretty good following of DBC ( BARC) users in the UK.
If at a latter date you want some of the best sounding files availble you can add the Benedini that is also plug and play with the BARC.
It is only am matter of time before you will be getting rid of the propriatory Heng Long orTaigen radio. You can buy better( hobby grade) radios for less money, so my advice is you should.
IF you want any of the compatible battle systems with sound you will have to lose the factory radios at some time. Plan on a hobby grade radio with a proper receiver, and then you have a broad selection of sound and battle systems once you have made that choice.
