[QUOTE=Beachy1968;12023441]I have an iGyro 3E which I intend to use in a large L39. In order to test it I have installed it in my Ripmax Xcalibur. As soon as I switched it on I noticed the jet felt more locked in but a slightly less favourable effect was that it also felt like the model was less responsive to small inputs, sort of like how I'd expect it to feel if I increased the amount of expo in my transmitter. As a result I've had to reduce the expo in order to sharpen up the small input response to feel like it did with out the gyro. Is this normal for this unit?[/QUOTE]
Mark,
Yes, that is normal....at least for the Cortex. I was advised to dial the expo down at least half of what it was before using the gyro to avoid exactly what you describe. I assume it would be the same for the iGyro.
Craig
