Originally Posted by
chris923
They do a have an affect, if you deploy at too high of a speed the plane will "balloon up". If you deploy them too late at a slow speed, you can stall. If you see no effect, them you are deploying them correctly. If you fly into a 15-20 mph wind you do not need the flaps to land. If you are in a 10 mph or less wind you will need flaps to slow to a landing speed with enough power to land with out stalling unless you have 1000ft to land on.
I would say you are using them correctly.
I don't deploy at high or low speed..so I guess I,or we since there are two more, are deploying more or less at the right time.Now my P47 is totally different,pitches up drastically at most any speed.
