Originally Posted by
captinjohn
Would one you guys that has a Saito apart or have some broken engines measure some valve for me. I am working on a 4 cyl old time engine. Looking for a valve with a head dia of around .430. The length would need to be close to 1.375 in length. Sharing this data would be great for those building cast kit engines. Thanks Very much in advance. John PS any other brand valve sizes too !
I don't think you are going to find any Saito valves that will fit your project.
FA-150 valves are .542" in diameter. The bad news is that they are only 1.252" in OA length. This is the smallest valve head in the big block series (same as the FA-120S) and yet the OA length is too short.
You might find medium block valves W/a diameter that is close enough to grind to spec, but then the OA length will be even shorter.
