RCU Forums - View Single Post - M4a1
Thread: M4a1
Old 04-18-2015 | 02:06 AM
  #73
Ex_Pat_Tanker
They don't fit the Mato metal sprockets - I've seen people try them when they first came out, and even after some serious dremeling to the sprocket hub, they still don't run right. Sounds like you have a bad set, as I haven't seen bent pins on new tracks before.
(also the track pins are different between the metal and plastic versions, so you can't even use them, nor the edge connectors )
