All in all probably a useable engine, but it's worn. I don't believe it is "virgin". The sideways sanding/score marks in the cylinder were made by someone with too coarse a grit sandpaper. The base gasket does not appear stock, and it is covering portions of the transfer port passages, and the transfer ports appear to be the small ones. The piston is worn. Normally I use a Bowman ring in the top groove only, and a stock ring in the second groove. It appears to me that a piece of the second ring is broken off right where it is supposed to fit over the pin in the piston on this one. If the top ring is undamaged, just use it in the second groove.
The engine can be rebuilt and will run, but it is not the best candidate for an engine you are going to put a lot of time into souping up due to the wear on the piston and condition of the cylinder. It is a 30cc. The fastest, easiest way to tell a 25cc from a 30cc Homelite it to just look into the exhaust port. The 25cc has the bridge in the exhaust port while the 30cc does not.
