Carefully cut the raised metal off with a sharp knife, then gently file or sand the area smooth. It shouldn't hurt a thing from what I can see of the pictures. I sometimes grind the piston in certain engines half way down to the ring groove in the area of the exhaust port. There's material to work with on the piston top.
AV8TOR
