Junk... Pitch the top end. Look at. the wear patterns. The piston skirt is well worn and it has caused some wear in the jug. Most two strokes that die for causes other than melting down die because the piston wears, it starts rocking in the bore, then breaks the skirt off then boom.... Hint is all of those machining grooves you can see in the piston near the rod.... Guess what on a new piston you will see those run all the way around all nice and even... They actually help hold the oil film for lubrication and reduce drag. Notice how near the ring they are all still there but as you move down the piston, they dissapear. You can see the wear the rocking has caused in the jug.. you would probably need to go well over .030 on a bore to get it round... Dont waste money on a new ring, it will just get you to the end sooner. Find another in better condition for your final product and use this one to learn on...
