Epoxy shouldn't be bothered with outside moisture or humidity. I did find if I mixed with a stick instead of a brush it didn't mix as well and took longer to cure. I buy acid brushed by the gross just for mixing. When I was making gun stocks I did have a problem with the finish not drying when I did one on a rainy day. That was with poly U.
