Originally Posted by
Lone Star Charles
Interesting. Did you find the prop? If so, can you post photos? Would especially like to see the hub where it contacts the flange.
Unfortuately I did not.
spaceworm
What grade of bolts are specified/used? What torque value is specified? Thanks.
Whatever Valley View RC provided with the prop adapter - I have no idea.
R/C Art
grosbeak - sounds like to me that you know what happened. Bummer.....but kudos on the save!
I do have my suspicions... and thanks!
spaceworm
Sounds like adverse yaw, and you need to add aileron differential. Also, you may need to add rudder to lift the tail on turns. Much like a Cub needs the same for coordinated turns. Good luck.
Sounds like a plan - I figured I was forgetting something!
