RCU Forums - View Single Post - Large engine electric starter
Old 04-21-2015 | 04:49 PM
spaceworm
Originally Posted by rtstestpilot
I have seen the gear reduction starters Richard and am looking into possibly making my own using one. ... The question I have with one of these automotive starters is - does the small gear move on the shaft like a normal starter or does it only turn? Not sliding on the shaft would make modifying one for our purpose much easier. ...
Todd
I didn't know, so I Googled up how starters work. It said that the old Bendix drive had the gear on a helical cut shaft. After the car engine started it would drive the starter gear down the helix and out of engagement with the flywheel. But, it said the Bendix drive is obsolete and more modern starters have a one way "sprag" drive that is like a one way clutch. So, the starter gear does not slide laterally on the starter shaft, which is good for our use. Good luck with your build.
