Originally Posted by
Chris_WaterBoy
Rich,The tip re: Fitting/gluing the wooden dowels before re-drilling the mounting holes would be the best solution I think, assuming it will be strong enough not to dislodge from a slightly harder than ideal landing.
I would definitely be interested in the hardwood kit. Your build manual too, if available.
I'm fitting a Jets Munt 100 turbine. Does the wood kit include some adapter plates for the smaller diameter turbine?
Thanks, Chris
Chris,
the manual is under final review, so it should be ready by the weeks end.
As far as the wood kit containing an adapter plate for the turbines, no it does not.
Actually I believe the Jet Munt turbine comes with a mounting plate that should span the mounting rails.
The rails are space approximately 4.35" apart.
