Originally Posted by
Stone17
Building a TP GS P-47 ARC right now. I still have to beef up my cowl mount blocks.
Check out the attached PDF for the template. The PDF is to scale. Just print to 1:1 scale and should be good.
The small block in on top and the larger block in the bottom one.
Glue is not enough add small screws,mine kept breaking loose until I added reinforcing blocks and screws
