I checked the wing incidence this afternoon on mine and found the bottom wing with .25 degrees positive and the top wing has about 1.5 degrees positive. I don't recall where it balances, will check when I get out there tomorrow and let you know. I do recall though that when we first checked it, it was in the reccomended range but slightly aft of the center of that range. Still within spec but this plane sometimes feels slightly tail heavy for my preferences. I think if you balance at the front of the cg range you will have a good flying plane. In any case I'll look tomorrow and get back to you with an exact location.
Rick H.
