Originally Posted by
757Driver
Super news about your maiden. You know guys are using 100mm from leading edge for CG now with pleasant results. This is where I'm setting mine.
Another issue I ran into was the wing bolt holes not aligned with the wing. See pic.
I'm going to use a metal coating process. The tip tanks were done as a test and they are acceptable. I want my airplane to have an extremely high polish look like these birds did. The last pic shows my tip tanks.
I was aware about the cg. The tip tank looks fantastic. How much weight you believe this process will add?
