RCU Forums - View Single Post - Please explain exponential
Old 04-23-2015 | 06:28 AM
Rodney
Whether or not you use negative or positive expo depends on the system you are using; for instance with Futaba you use negative expo but for Specturm you use positive expo for the same effect of reducing movement near neutral. Be sure to read your instruction manual to see which your brand transmitter uses (+ or -). If you set it wrong, you will have a very exciting first flight.
