Thanx for the replys guys. Out of the box it had a line where it curved up from flat, which obviously is cut off, and above that is a fine line all the way around but if I cut that it will be too short to sit down on sides of fuse. Also yes it's allready covered so I'm thinking cut it down till the back of the canopy lines up with the arch in the headrest without touching stringers. I don't think I could turn it around tho since the back is allready cut out for the stringers? I can always cut off more but I don't want to be buying another canopy if this doesn't work.
