RCU Forums - View Single Post - Please explain exponential
Old 04-24-2015 | 06:47 AM
drac1's Avatar
drac1
Originally Posted by mackeyjones
I fully understand what was meant by flycatch's original comment, I dont use dual rates but use exponential instead there really is no point having both unless you have no idea what your throws should be at intitial setup or for 3d, but it comes down to your own paticular flying style. Expo really allows smoother movements around the centre of your stick, while being able to a have large rate movement around the end of your stick movement without having to flick a switch.
Expo is not used instead of dual rates, they are 2 completely different things. I use triple rates for precision aerobatics and set different expo for each rate. Each needs to be fine tuned to accomplish what you need to do.
