Originally Posted by
olmaugeard
Hi everybody
this week in Frnace it's was the mainden fligth for my AVANTIS and the F14 fron eric.
Both plane need no lead ( Yes 0 g !!) for the CG value !!!
The kingtech 210 G for the AVANTIS and 2 P160 Jetcat for the F14.
3 tests Flight in the same day for each plane...and all were OK !!
hello olmaugeard,
congrats on on the maidens!
I noticed that you have cutted the bifurcated air inlets in the fuse. Why? Is it to save weight ? Also noticed that you opened the retract holes, good ide I will do the same as I am using a BF300 turbine and will need all the air inlet I can get.
i am a little worried about the vector thrust tube as it has small travel imo, i saw the changes you made to it.
Ziv
