Art, so i was checking with the glow plug not where it connects to the data terminal when i loosened the glow plug about a 16th of a turn the egt probe sysrted reading temp, so i tried to start the engine but i noticed the fuel solenoid would not deliver fuel so i stopped the start up, i primed the fuel pump same thing fuel solenoid wouldn't deliver fuel i know it works so i ran the fuel pump directly to the engine pressed run from data terminal, gas ignited then ramping fuel ignited then running from data terminal egt was 300, rpm was 50k then it spooled to 90k without me pushing the inc button so i stopped the run!!
